Can't get a straight answer on Tire Size
I have a 2006 f-250 4X4 King Ranch. Short box. I need to get these crappy Cont. tires off of my truck and I was wondering what the max tire size that I can put on my truck. NO LIFT. I have been told that 325/65/18 will not rub but I don't know if I trust that statement. I have stock 18" rims. Can anyone shed some light on this for me?
Thanks!
Thanks!
Generally a 325 is a bit too wide to run on a stock rim (7.5''), but is done from time to time but not usually recommended unless you are planning on putting new rims on at some point. Also, a 325/65R18 is going to be a bit big without any sort of lift, you could go with a 325/60R18 (33x13) but the same rule applies for rim width.
Best bet would be a 305/65R18 or 285/65R18, (34x12.50ish and 33x11.50) respectively but would still recommend a leveling kit.
