17x9 pro comp 35" fit?
I'm thinking about getting some 17x9" Pro Comp 1069 wheels (4.75"BS -4mm offset) with 35/12.5R17 tires. I have a 2006 supercrew 4x4 with 2.5" AS front leveling kit. If I do trimming will they fit? Would Bilstein 5100's help? If not what lift kit should I get that will not empty my bank account? Thank you all for your help.
found this setup, encouraging...https://www.f150online.com/forums/me...fc6212a31.html
The more the tires are kept tucked in the front wheelwells the less rubbing you will have. If you don't mine some rubbing at low speed's mainly when making hard turn's they may work with the close to 5 1/2" BS. You will have to trim and tuck back the lower wheelwell liners. Also any offroading they will rub. I agree with Wandell with maybe going with a bodylift to clear these tires.
