Shaking between 60-70mph
ok here is the problem, I put some 305/65/18's on my 2007 F-150 and they had a bad problem shaking between 60-70 mph, so after getting a wheel alignment and 3 rotations and balances later still no change. So I had them put 285/65/18's on it and the same issue 2 roations and balances and another wheel alignment today and still nothing. I have had the rims checked out both times Btw. Any ideals?????
ive seen this problem before working at tire shops, couple suggestion, you might need to get hub centric rings in order for those rims to fit properly, another thing is sometimes they dont seal the tires properly, go back to where you had them installed and ask them to reseal properly. This means taking the tire off the rim, applying tire paste not lube when mounting the tire and inflating the tire to 90psi to let the tire expand and seal completely , then lowering the air pressure to what u want it at. Also dont let them do a dynamic balance, its not a true balance for as it only balances the inside of the wheel once you properly seal the tire a normal balance should be easy, also make sure that the mounting surface of the hub is clean and has no surface rust or oxidation. This should fix the problem, Its what ive done whenever i came across this problem, and ive never had a customer complain after. Just in case your wondering , i have over 7 years exp. in a tire shop, doing customs from your every day ricer to bmws and heavily modified off road trucks.
Jordan...I've had this problem also for quite some time. Been to 10 plus shops and none of them did any good, fancy machines and all. I suggest finding someone who has been doing tire work for at least 20 yrs. even if the place looks like a dump and was built in the 50's. Thats where I found this little dude with a balancer that looked like it had seen its better days and he fixed my truck. Its definately the GUY behind the balancer that will take that shimmy out. Best of Luck and thanks for your service to our country.
