BFG AT Tread Wear!
Tire pressure is relative to footprint. I'm too tired to explain the math now, but 35psi sounds about right for the increase in size. I just put on my 35x12.50-20 Toyo's Friday....set them all to 30psi. Tomorrow, I'm actually gonna check the pattern to see if it's optimum. I may go up to 35.
I don't know why your tires seem to be wearing so quickly. But I seriously doubt "only" having 35psi had anything to do with it.
His truck probably came with P series tires, which have a recommended pressure of 35 (max for tire). If it came with a LR C tire the recommended would have been 40 (max is 50).
If your tires have a max of 65, I recommend you get them up to at least 40-42.
Tire size has everything to do with required pressure. The more tire you have on the ground........the less pressure you need to hold up the same amount of weight.
At max pressure my rear tires will hold 6400 lbs..........yeah, 6400 pounds....that's more than my entire truck weighs. My maximum rear axle rating is 3850. So yeah......the maximum weight my tires will see ever see is about half of their rated capacity.
But anyways, back to the pressure thing. Let's assume my 35's have nearly twice as much rubber on the ground as my stockers. That means that they would require half the pressure to support the same weight. Meaning that at 22.5psi, they'll support the same as my stockers at 45psi.
But, that's a little bit of an exaggeration.......they don't have quite THAT much more rubber on the ground than the stockers. I was just using that as an example. But the principal is the same. Realistically, the tire probably has 50% more tread on ground....so 30-35psi would be about right. The only way to know for sure is to put a line across the tread and see how it wears off.
Also in your example of your tires. 6400 might be what they add up to, but at 30 psi, they will be able to handle less than half that. Your vehicle is rated by axle at about 4000lbs per axle. You are well below that rating at 30 and 35.
I run LR E tires that have a max of 80 at 50, with perfect tire wear. LR C with a max of 50 at 40, with perfect tire wear. These on an F150.
For the new TPMS systems where the vehicle came standard with a LR E tire with a max of 80, the TPMS would be set to turn the low pressure light on at 46. The lights are set to come on depending upon LR and max tire pressure, not width.
See this site, there is a chart about a third of the way down.
http://www.nhtsa.dot.gov/cars/rules/...e.html?name=#D
Ok, I'm gonna give you an extreme example of how a larger tire requires less pressure.
Are you familiar with industrial tractors......like a rubber tired back-hoe for instance?? Some of the smaller models have front tires similar to a truck tire.....mounted on wheels that are about 17 inches. And, on the rear, they have a larger flotation tire. The recommended pressure for the front tires may be 45psi, but only 20psi for the rear. And even at only 20 psi, the rear could hold more weight than the front ever thought of holding. Why? Because it's a taller, wider tire.
I understand what you're saying about the vehicles with TPMS and load range E tires. That's for vehicles that NEED a LR E tire and NEED 80psi to function properly. An F-150 will never NEED that much pressure. Just because you have a tire that will hold that much pressure doesn't mean that you're required to run it......on a vehicle that doesn't require it.
And I'm not going by width only. Because simply an increase in width doesn't change anything. If you increase your width, that also lowers your section height. So even if you have more tread on the ground side to side, you have less tread on the ground front to rear. The contact area stays about the same and the required pressure stays the same.
Ok, I was going to try to explain this a little better...........but I'm just gonna cut it short and give you one more example. There's a 2000 Ranger sitting outside my window with 285/75-16 Load Range E tires, and only 25psi in the rears. Because, with any more pressure, only about a 3 inch wide strip of the tire actually touches the road. I had another Ranger with 33x14.50-15 Super Swamper SSR's. And even with only 20psi I couldn't get the outside of the tire to touch the pavement.
So if you like running alot of air pressure and have had good results, that's great. I like to run my tires with less air........when it's required. If I'm gonna be towing something heavy, I'll air my tires up. But otherwise, I want the full width of my rear tires on the pavement.....not just the strip down the middle. I'm not encouraging anyone to let air out of their tires.......because, yes, it CAN be very dangerous in certain circumstances. All I was trying to do is make a point that having only 35psi in a set of larger than stock BFG's wouldn't cause any irregular tire wear after only 500 miles.
Nowhere did I state you need 80 psi on a LR E max80 tire for an F150. 50 does just fine. 35 would be dangerous.
If you want to talk about high pressure tires, look at a tractor trailer tire. Large tire and meant to have a max of around 105.
