BF Goodrich ATs in the winter
Good to hear they work well with good tread. I've been a little disappointed with mine in the snow, but last winter they were down around 6/32. My complaint is they don't seem to steer very well (front end pushes) but do have good forward bite even being as worn out as they are. Not trying to bash them, I've never had a new set and never had a decent tire on this truck to compare them with.
The above traction complaints are not surprising. Keep in mind that just because it's an A/T tire does not mean the tire gives good hardpack and ice grip. The rubber compound of an AT tire will get hard in the cold like any other tire will. Only snow tires will stay soft in the cold and continue to grip. I have driven brand new Goodyear MT/R's right into a parking lot pole because they were cold and sliding. Why? Not snow tires......
Don't confuse snow traction and ice traction.....
As far as the tires, They are the best tires you can buy for every situation you can come by. Great in snow, great on the road and great on dirt.
Hi, I just put a set of 285/65R18's on my 06 F-150, so far I really like them and they performed well in our first taste of winter. The one thing that was brought up to me is that they have two different styles of siping, and you have to watch which one you get in some sizes. The dealer said for the most part, the 10 ply ones don't have as much siping, are a little harder, and a little less tread depth. But in this size they only make a 10 ply so it does come with the winter rating which includes more siping. If you look at them first you can definately tell, mine have 5 sipes per lug, and the non-winter rated have 2. These tires do definately give a more firm and positive ride than the stock Rugged Trails did.
