Paint your OEM wheels: Step by step w/pics (56k warning)
#46
No problem, man. Those look fantastic. You did an amazing job...can't wait to see them on the truck!
#48
#49
How did the logo masking go? I swear I spent just as much time taping the wheel as actually painting it. Haven't done the caps yet... was it a PITA?
I just painted my OEM 17" Expedition wheels that I use in the winter time and they came out great. I did it with the wheels off the truck and masked off the Ford logos before painting so they still show. I am very happy with the results. Pic was taken with my cell - sorry for the quality.
#55
The end result looks good, but I'd have some concerns about painting them on the vehicle:
1) Already noted: Wheel weights and over-spray.
2) Lug nuts - the first time you remove a wheel, they will get all dinged up.
3) Center cap - if removed, and not placed exactly in the same place/orientation, you'll have bare metal showing?
I also like the 2-tone that Janos150 and Torquet did. I wonder what it would look like reversed.....
Andy
EDIT: Looking at Janos150's close-ups, maybe a reverse scheme wouldn't work.
Andy
#56
1)I took my wheels and factory wheel weights off.
2)I always have an impact socket wrapped with a layer of electrical tape for use on wheels, not fool proof but helps out.
I actually drove around for a week without getting the tires balanced. I had less of a vibration then before. Then i had a set of used toyo 305/50R20's put on and the sticky wheel weights put on on the inner side of the wheel. I found a couple of scuffs after they swapped tires but I easily touched them up and you can't tell.
I really need to wet sand them when it warms up. I painted the backside of the wheel at the same time and it caused some ruffness around the spokes.
Thanks everyone!
Thanks everyone!
