Pro Comp wheels
Pro Comp wheels
I think I finally found a set of wheels I would like for my truck. Pro Comp Xtreme Alloys, 18x9s, cast blast finished in black. I'm not very well knowledged when it comes to suspension and wheels but will I be able to fit these with a 2" level? Hoping to buy wheels and tires in the spring. Running a Bilstein 5100 2" level, and have future ( distant future ) plans for a lift. Thanks.
http://www.4wheelparts.com/Wheels/Xt...n=PXA7089-8936
No problem. I had the 285/65's on my truck before and I think you'll really like them. If you aren't dead set on the 18" wheel size BFG also makes a 285/70 17 which is just over 32.5 inches tall. It's essentially the same height as the 18 but cheaper. Pro Comp also makes that wheel in a 17x9 with the same backspacing as the 18. I'm only saying this because you said affordable. That is a good looking wheel by the way.
https://www.f150online.com/forums/wh...te-w-pics.html
incase you forgot this thread, she got them in 305/65/18 i believe. i think your truck would look sweet with that setup, Darren
