offset ? for xd spy 797
im looking at some kmc xd spy's for my truck. i want 20"s and 35's. right now my truck has 2.5" as and AAL's if i decide to put them in. so my two options are
![](https://www.f150online.com/forums/members/sherrod624-albums-truck-pics-picture13905-mxd7973.jpg)
20x9 -12 offset and 5.47 backspacing
or
20x8.5 18 offset and 5.46 backspacing
so my question is, and ive searched what will be the diffrence when they're mounted on my truck? and how will the set in the fender wheels, wider than stock, same as stock???
or
Wheel width and backspacing are just as important to fitment as the actual tire size. A lot of people here are running 35's, but almost all of them are using the oem wheels. The few that have aftermarket wheels are using ones with almost the identical width and backspacing as the oem wheels. The wheels you listed have the right amount of backspacing but are a little too wide to fit 35's with only a leveling kit. The 20x8.5's may work if you use the 285/65-20 BFG AT KO's because they are a little narrower than most.
Not being an *** Wandell but just trying to help the guy out.
This guy doesn't say the specs of his wheels but...
https://www.f150online.com/forums/su...led-w-35s.html
Giorgio-pics
https://www.f150online.com/forums/20...5-mt-pics.html
-specs
Well damn I can't find the specs in any of his post and in a few he didn't know them.
Grubrunner-specs on p.3
https://www.f150online.com/forums/20...view-pics.html
05extcabflare-pics
https://www.f150online.com/forums/20...g-kit-35s.html
once again can't find the specs and he doesn't know from what I've seen
Ford141-pics/specs
Thatis0n-pics
I can't find the the specs but the wheels are AE 026 so look at there site and you can figure out what the specs are I bet
Ameration-specs/pics
https://www.f150online.com/forums/2863534-post19.html
Dog'em-pics/specs
https://www.f150online.com/forums/wh...els-tires.html
Hope that helps bc I just spent way to much time searching for those damn post.
Giorgio-pics
-specs
05extcabflare-pics
Ford141-pics/specs
Thatis0n-pics
Dog'em-pics/specs
Well, we know you can fit a 35x12.50 using an 8 inch wide wheel with 5.5 inches of bs. Will that 8.5 inch wide wheel you listed work? Your gonna have to try to find out. My guess is you will have to do a little trimming.
so if ive done me research correctly offset, to some extent, means nothing if i know the backspacing and rim width. as is if the rim width is Y and the backspacing is X then the offset will ALWAYS be Z. right??
so since the stock 20's are 5.5" back spacing and 7.5" wide then if i use a
9" rim with 4.5" backspacing it wil stick out 2.5" more than stock and
8.5" rim with 4.5" backspacing will stick out 2" more than stock
add the width of the the tire to it and that means 9" rim with 11" tire will stick out 5.5" from wms and an 8.5" rim will stick out 5" from wms.
right???
so i could take a piece of cardboard and cut out a 34x5.5or5" square and hold that centerd to my hub and see if its gonna hit right????
and the above statment is taking for granite the only thing im gonna hit is the outer fenderwell.
withought me taking my tire of and doing this to see for my self What if anything will i have to trim??? the inner fender or the acutal outer sheetmetal of the truck??
right???
