tire pressure question
Good way to have problems. The size is meaningless. I can find P series with a max of 35, LR C with a max of 50, and LR E with a max of 80 in that same size. 35 would have been listed on the door for the P series tires. 40 would have been listed on the door for a LR C and at least 50 would have been listed on the door for a LR E.
Now again, I agree with you if the tire isn't the correct LR and won't handle the higher psi but that tire wouldn't be to factory specs and shouldn't be on the truck anyhow.
I understand what your saying and for whats it's worth I agree. However if your truck calls for 40psi then you should match that with the appropriate tire. If you follow the recommendation on the sticker I can't see how that could bring you problems when it came like this from the factory.
The proper way to determine air pressure needed is to put a couple chalk marks across the tire then roll the vehicle forward and then check the chalk marks, a properly inflated tire will rub the chalk off evenly across, overinflated the center will rub off first and underinflated the edges of the tread will rub off first.
