wheel question
wheel question
lookin for advice...
I am putting the 2.5" level and 1.5" aal in the truck (2005, Screw, 4wd, 5.4)
I would like to put 305/55/20 - 33x12.5/20 tires on my truck once I put the lifts in.
What type of wheel diameter, offset, backspace should I be looking for if I dont want the wheels to be sticking out too much? 1.5" at most
I was interested in some eagle 064's 20x10, -21mm offset, 4.626 bs
I am I correct in thinking this wheel will stick out quite a bit?
Thanks for the help guys!
![thumbsup](https://www.f150online.com/forums/images/smilies/thumbsup.gif)
Thanks Wandell...
a couple of things then...
If I get a 9" diameter wheel should I be looking at
275/60/20
or will I be able to use 305/55/20
I have found a wheel! Incubus 518
20x9 12mm 5.5
18x8.5 12 mm 5.25
how far are these wheels going to be sticking out?
what size tire should i select to go with either one?
i was looking at aggressive tires, mc atz, toyo m/t's, proc comp xtreme, bfg a/t and km2, cooper stt, kumhos, nitto terra grapplers, **** cepek ETC
thanks again for your help, you are really saving me
i wish there was a tire shop close by...
275/60/20
20x9 12mm 5.5
18x8.5 12 mm 5.25
