What Mud Tires Look Best Wrapped on Stock 17" Mach Rim?
Hey, I got a 08 STX 4x4. Im planning on installing a 3" Level in the front. Im going to keep my stock rims, because I like the way they look, and im cheaping out. They are the "mach" type rims. If anybody has pics of these rims wrapped on a mud terrain, please post! Also, id like suggestions as to what looks good! Thanks.
I think most everybody here will steer you clear from a 3" leveling kit for two reasons:
1) Too severe of angles are created up front with the upper ball joint and cv shaft
2) Unless you do the 3" block in the back, your front end will sit higher than the rear.
2.5" leveling kit is the max most go with.
As for the tires, I love the look of the BFG KM2.
