97 ford with 305's?
really? your 285s rub? when i ran 285s i had no problems and still have none with 305s which are an inch wider than the 285s. make sure you turn each side equally, one of my bolts have a few threads left til they would be maxed, i didnt want to do that with mine though. it only took about an inch to level mine out. they all come different from factory. a few turns on each side should level it up.
you will see one side has more threads left than the other, this is because of the different weight on each side of the truck, gas tank etc etc...just dont try to make both the bolts even.
