**** Cepek Tires.......Beware........
![Mad](https://www.f150online.com/forums/images/smilies/mad.gif)
Those tires are covered under manufactuere warranty for out of round within the first 2/32nds. They come with 20 new, so as long as you have 18 or more you can get it covered. Says so on the back of my Cepek standard limited warranty. Here is there website contact info, http://www.****cepek.com/contact.html email them and request a copy of the standard limited warranty info.
I work sales at a tire wholesaler that is nation wide, so dont blame the tires because your retailer is full of ****. If you mailordered it might be harder, but any reputable retailer should handle this for you. If you are mounting yourself and getting a lot of weight, make sure you are match mounting. Meaning highside of the tire (the little dot<< thats that it means) is opposite the valve hole. A lot of the time that helps with the balance.
But go back to your retailer and get your stuff handled and dont let them put you off.
Once your past 2/32nds your screwed for any ride disturbance,
My FC II's are great too, no probs and had them about 13mos. Keep after the retailer and **** Cepek and get BBB in on it like the others said, that a load a of ****, they shoud both be trying to get you a new tire. good luck
Theres another guy on here "NoLongerJeepin" that has them and hasn't had any probs either
Well, after almost 2 weeks, I finally spoke to a "real" person at DC. I was sent to the warranty dept. and told them my problem. After convincing them it was my tire, they were certain it was my wheel, they called the warehouse where I got them, and had one sent to the tire shop. I should get it tomorrow. Thanks for all your input.
