ABS Light
ABS Light
I have a 97 f-150. The ABS light is on, the pedal is soft and you need to push hard. If I push the pedal down without the engine running and hold, then start the truck while still holding the pedal down, the ABS light goes out. When I release the brake pedal the light comes back on. I just changed the master cylinder and bled all the lines. Could I have a bad caliper?
