need opinion/help 245/45-18 on stock wheel
i have a 07 supercrew that has the factory 18" wheels on it. It has 2" lowering shackles in the back right now, front is stock height. It has the 265/60-18 bfg tires on it.
I want to go to a little lower profile tire that will fit the stock rim and look good with the 2" lowered backend.
I'm thinking a 245/45-18 riken raptor tire.
any suggestions, opinions or does someone have something similar that i can see a picture of?
what is the width of the stock wheels and backspacing?
That tire is about 4 inches shorter than what you have now and about an inch narrower. Your rpms will be up there cruising at highway speeds. If you are wanting a low profile tire, you need to get a larger diameter wheel and stick with about the same diameter tire. The stock wheels are 7.5" wide with I think 5.5" BS.
