which rims should i get
Im running 325/50/22 grapplers on a 22x9.5 with 30mm offset / think 6-1/2 backspacing. Have 2.5 AS level kit and swap stock 2inch blocks for 3 inch blocks. Wheels not on the truck yet. IF running that tire with just a level kit and 9.5 to 10 wide rim...keep the offset between 18mm and 30mm. Member here has monsters with the 18 and has slight rub on outer fender edge when turning in reverse.
