315's on 17" rim
315's on 17" rim
Can people post photos of 315/70/R17 tires on 17" rim. I am looking at buying Pro Comp 1079:
* 17x9, 6 on 135mm Bolt Pattern
* Backspace = 4.75 in.
* Max Load = 2200lbs
* Finish = Polished
* Hub Centric = No
* Offset = -6mm
Just wondering what these would look like. I don't want them to stick out more than an inch from the fender well....
These rims should work for my 08 FX4 Screw, right? I have a level kit right now, and for the time being, I will just add a block to the rear to raise it up a inch and a half.
* Finish = Polished
* Hub Centric = No
* Offset = -6mm
tires are bfg at
pawpaw's truck
straight on shot. wheels are 17x9 4 5/8 backspacing with -8 offset. i think we figured out one day lift kit widened my front track width .75" or so on both sides. you will probly rub if you dont do a full lift kit. i would go with a 33" tire unless your gonna lift.
pawpaw's truck
it depends on the backspacing if they will be "deep dish"
i just bought a set of 15x10 MT classic locks w/ 3 5/8 backspacing and their deep dish, so i would think if the backspacing is 4.75 it will be fairly "deep"
im sure 4wheel parts will have a set in the back for you to look at.
if you order wheels call onlinetires.com they are really cheap compared to any where else i looked. btw the new KM2's are sick if your thinking about getting tires. i got them on the locks and they look sweet.
