What Tires to Get?
What Tires to Get?
I am a newbie when it comes to what tires I should buy. I have a 2004 F150 FX4 Supercrew 4x4. I am looking at the KMC Rockstar black wheels but am unsure what tires to buy. I am purchasing a 2" leveling kit and am wondering if I should go with 18" or 20" tires. I am Looking at Nitto Terra Grapplers, Toyo Open Country AT or MT, or Firestone Destination MT. I basically want an aggressive look with the largest tires i can fit without a suspension lift. I am also not going to be off roading that much and I would like to spend about $2,000. Any advice and pictures will help. Thanks
x2
18" are just right. 20" tires are expensive to replace compared to 18" tires. Plus riding on rubberbands (short sidewalls) will be fine in you spend all your time on pavement, but 20" rims get a little silly off road and in the snow.
As for the tires I recommend mud tires if you go off road much.
1. Mikey Tompson MTZ
2. BFG MT
Also Cooper tire makes a very nice newer mud tire, with good side biters and high void tread but i'm unsure of the name. I've heard nothing but good things about this tire. I belive the Mickey Tompson MTZ tire is based on the design or vise versa. I'm sure the Coopers would be a little cheaper the the MT MTZs.
As for AT.
1. BFG AT
2. Mickey Tompson ATZ
I would stay away from Good Year and Firestone products. Good Years are not worth the price and the Firestones are low quality tires. But in about 2 seconds someone will disagree.
2. BFG MT
As for AT.
1. BFG AT
Hey I actually just got Rockstars put on my 285/60/18 Toyo A/T's. Got a picture of my truck as my signature and I have a few more pictures in my thread:
https://www.f150online.com/forums/wh...oday-pics.html
Hopefully that helps! My trucks an 2005 2wd.
If you want any pictures of my set up or anything just ask.
Check out abarkerr2's truck, I think it might be exactly what you're looking for. He has a 2.5" leveling kit and is running 18x9s with 305/65-18 tires, which is basically a 34" tire, 33.61 to be exact and it fills is wells out perfectly. He had a real minimum amount of rubbing that required very little trimming of his flare. And if you scroll down a little you can see what he had to trim. https://www.f150online.com/forums/wh...ml#post3316688
I love my setup with 305/55/20 Mickey Thompson Baja ATZ Trad. They look real aggressive, ride great, and handle great in the mud/snow. I'm running a 2" leveling kit with these too. Here is a pic of them, got a lot of other pics in gallery if interested. Picked these up at 4wheelparts installed for $1300
