will this fit.lol
will this fit.lol
i have a 3 inch truxxx (spacer) and have been running 315/70/17's on stock rims.im looking to get some new rims and tires but keep the spacer lift for now.im looking to run a 17x9 pro comp 7005 black rims.I get confused on the backspacing thing.the back space on that rim 4.75in.So would they fit better then the stockers? rubbing?i wanna get another set of 315/70/17 tires.i wanna run 17 inch rims and tires.Thanks
sorry 2WD
some people say 5.5 b/s but i cant see why a 4.5 or 4.75 wouldnt fit
sorry 2WD
then what would you suggest? a 17x8? should i try a smaller tire like a 285/70/17 with the 17x8 or 17x9.agian its a cost thing and i dont want 18's or 20's.Thanks for all your help
The more you stick out in the front caused by a wider wheel and backspacing more than stock you will have rubbing problems in the front. Usually the lower wheelwell area. A 9" wheel with 5 inches of backspacing will stick out 2 inches more than stock. A 8" wheel with 5.5 inches of BS only 1/2" more than stock. The wheels have to be tucked inside the wheelwells so the tires won't rub in the front when turning. Usually the largest tire on a leveled 4x4 would be a 35x12.5. The same rule applies to 17 and 18" wheels.
