ABS Fail
Thanks, i had a look today above the rear differential, but not sure i know what i am looking for. Does anyone have a pic of a rear ABS sensor just to give me an idea of what i am taking off? Since it is the first time i am replacing this.
thanks
99 4.6L 2WD
thanks
99 4.6L 2WD
I don't have a pic of the sensor, but it's the only thing on the differential that plugs into the chasisis wiring harness. When I had the same problem, the wire harness was cut near the differential. I spliced in some new wire and covered the splices with a new piece of wire loom I bought from Murray's.
Hey man i have a thread started about the same thing
https://www.f150online.com/forums/wh...-couple-s.html
The sensor can not be missed it just about the rear diff where the d/s inserts into the diff.
It's probably pretty dirty there and it has a connector that should be un-clipped and then it's just 10mm bolt towards the back of the sensor.
I pulled mine and it read 1900 ohms so i think mine is bad.
Dealer wants $34 for it so i'll check napa instead.
Here's a great link:
http://www.ohmcheck.com/abssensor.htm
