What he's saying is a 37x12.50-20 will fit the OEM 20x8.5 inch wheels. The quesion is what are the specs on the truck the tire/wheel is gonna be mounted on?
the stock rims are 20x8.5. i personally feel that is too wide of tire for that rim, ideally that should be put on a 20x10 rim. you can put them on there, but they will wear prematurely.
A 325/60-20 is basically a 35x13.00 tire. That may rub the upper ball joint because of the OEM 20's backspacing. A lot of that will depend on the tire's tread and sidewall design. Aggressive MT's will be worse than most AT's. I'd go with a 35x12.50 at the most.
