can i plug this
tire repair
I've done tires for a LONG time, that can be fixed. I'd just plug it, if you don't want to do that find a place that still dismounts the tire and have them use a inside the tire radial patch! it covers the area about 2 inches each way. I'd just plug it like I said, then make sure you just keep it on the back.
I bout a new truck in 95, took it for a trip up in the hills and with only 43 miles on the truck a rock sliced one of my tires open... I mean big enough that it was flat in about 3 feet! Same area as your, but not just a hole... a slice. I patched it myself using the large radial patch and used that tire till about 35,000 miles till I went up to 33's from the stock 265's
Use a radial plug
Use a radial plug
