Tire Size, wheel back spacing, leveling kit, STD Questions
As with almost everyone else, after I searched I was more confused from the multitude of permutations then before reading.
I think I have decided on the final setup but I need to figure out the detail numbers.
2007 4x4 SCREW
Planning on getting the XD HOSS in 20s
![](http://www.4wheelparts.com/aux_incl/images.ashx?i=XD7952.jpg&partNo=XD&w=380)
Now here are the questions...
I would like to run a 35" if Possible with just a leveling kit.
Which AS kit is preferred 2", 2.5", 3" - I am assuming the 2"?
The wheel comes in 3 Backspacing 4.53"(offset -12mm), 5.71"(offset 18mm), 6.18" (offset 30mm) No idea which one is correct.
And what tire size should I be looking for? Any suggestions would be great too I have not done all that research since I wanted to know the size first.. (leaning towards a quieter Mud Terrain, or an aggressive AT)..
2007 4x4 SCREW
![beers](https://www.f150online.com/forums/images/smilies/beers.gif)
If I stick with those wheels I am looking at the 2" AS level correct with a 33x12.5x20?? or a 305/55/20?
Sounds like I will probably have to try it.
I guess I will also get the 2.5" Leveling kit should help out a tiny bit.
Looking at the BF Goodrich Mud Terrain T/A KM2
I guess for the 25 I am looking at 325/60/20 but DAMN $$$$![EEK!](https://www.f150online.com/forums/images/smilies/eek.gif)
I wonder if I get somewhere to mount them up and see and if not get the 305/55/20
I thought the 18mm offset would be better than the 30 though?
Thanks.. I ordered the 2.5.. Not sure if I will order wheels online, depends on price difference but I think I will get the tires from Discount / America's Tire this way if there is no way the 35s will fit they will swap them out to 33s without a hassle.
the +30 offset rubbed on the control arm at full lock
the +18 offset rubs slightly on the fender flare at full lock and driving reverse, plus they stick out further than the +30 for a more aggressive look
