Toyo MT Questions
it will be pretty close to the control arm b/c of the large side lugs , you might need wheel spacers , but they will fit ..........
They will rub the control arms at full steering lock for sure. Some member have had problems with the OEM 20's causing the sidewall lugs of aggressive MT's hitting the ball joint at all times. I can't remember if the Toyo MT was one or not. A thin wheel spacer will solve that problem but may cause other problems like vibrations.
