MPG change after 35s?
I have 35x12.50-R17 mud terrains on my truck, and it gets about 14mpg right now. 20" rims will have more of an effect on rolling resistance compared to a 17" with the same diameter tire because the 20" rim place the heaviest part of the weight (the tire) farther from the axis. The farther weight is from the axis, the more force it takes to accelerate and slow that mass. You will loose MPG, but probably not too much, and after you re-gear for the tires you should get some of it back.
I was hoping to not have to re-gear will have to see.. I do have the optional lower ratio I want to say its 4.10 or 4.35 can't remember would have to look it up.
If it is open road and I can set the cruise control at 70-75 I have gotten 18mpg with the lift and tires.
I was consistent with 13.5-14mpg with mixed country roads/town driving on stock 20's w/3.73 gears, larger v8 gas engine (can't remember, duh). After 6" lift and 20" 35's i am approx down 2mpg (11.5-12)
EDIT: After I corrected my speedometer for larger tires, the mpg calculation was corrected. I'm netting out at about a loss of 1mpg. getting 12.5-13 with mixed driving.
