Wheel and Tire Purchase Help!!!
I'm a new member and need some help...
I'm about to buy my wife a 2009 XLT SCREW 4X2 and saw some 20" wheels for $75 each and wanted to know if they will fit her new truck without being leveled. I eventually plan on leveling it when the money comes but didn't want to pass this offer up.
Pro Comp Xtreme Alloy 20x9, 6 on 135mm Bolt Pattern
* Bolt Pattern: 6 on 135
* Diameter: 20.00 "
* Width: 9.00 "
* Style: 12 Series
* Finish: Chrome
* Construction: Aluminum
* Backspace: 6.25 "
* Max Load: 2200 lbs
* Hubcentric: Yes
* Offset: 32 mm
I plan on pairing these with the popular Cooper Zeon LTZ 305/55/20.
Will they fit w/o the leveling?
Thanks so much in advance!
* Diameter: 20.00 "
* Width: 9.00 "
* Style: 12 Series
* Finish: Chrome
* Backspace: 6.25 "
* Hubcentric: Yes
* Offset: 32 mm
Welcome to the site. I deleted your other thread as it's against the rules to duplicate threads. If you don't get any help here, I can move it back to the other forum. Hopefully you will get some replys. If Wandell gives any advice, you can bank on it, as he is our resident suspension/wheel/tire guru.
I'm just guessing here because I've only seen a few of the 09's with aftermarket wheels/tire and or lift. But the wheel/tire fitment appears to be similar to the 04-08 trucks. I'm pretty sure that combo will fit with a leveling kit, but they may not without. The wheel has a lot of backspacing, which works in your favor but I'd still go with a leveling kit.
dude, i'm new on here also. before you close the deal on the truck, get them to throw the level kit in, at no additional cost. i just got mine in december and they threw it in the deal. i brought it back a week later and they installed it. truck sales are down so they shouldn't say no. if they do,tell them you'll take your business elseware.
