front brake assembly question?
on
*UPDATE*
After some investigating I found the the caliper is making the noise. When I hit the brakes over very small quick tight bumps the rattle stops. when driving over the same bumps with out riding the brakes I hear the rattle.
My question is????? do the slider pins wear out over time???? the caliper seems to be a little more loose than it should be.
thanks for the replies
