18mm or 30mm Offset for 4x4 with 2.5 AS
Going to order the wheels on Monday and wanted to verify before I ordered since I got a little conflicting information from the shop.
Just installing the 2.5" AS Level on '07 4x4 SCREW
I am going to try and fit either the toyo 35x12.5x20 MT or BFG 325/60/20 KM2s (undecided right now toyos are like $115 cheaper EACH)
getting the XD hoss and they have 3 setups for 20"
I thought it was recommended to get the 18mm OS with the 5.71" BS
However the one of the shops I went to said without a real lift the 30mm OS with 6.81 BS would have a better chance of fitting?
I can swap to a 33" tire if the 35s rub too much but not able to swap the wheel so I want to get it right.
I may be wrong but tires with large side lugs you had better stick as close to oem backspace as you can. The 5.71" bs might rub a little depending on how wide of a rim but I don't think the 6.8" bs will begin to work with either of those tires.
My BFG K/O's don't have an aggessive sidewall but it's close to rubbing with a 20x9 rim with 5.9 bs.
Thanks That's what I thought.. 18mm with 5.71 Its a 20x9 wheel.
I think guy at the shop was trying to push the 30mm because they did not have any stock on the 18mm / 5.71
![Mad](https://www.f150online.com/forums/images/smilies/mad.gif)
Blackout Fx4 and myself have 2.5as leveling and 22x9.5 with 34.8 grapplers. He is running 18mm offset and only rubs rear outer fender lip in revers. I on the other hand have the 30mm offset with the same tire....not yet on the truck. But I did test fit a 22x9.5 with 38mm offset and a 325/50/22 34.8 grappler before I was leveled all was good as for spacing not rubbing on the backside.
