Should I be worried...
If you drive though gravel alot then I would. If you just use it on pavement then I wouldn't say you NEED to do it. Mine stick out every bit of 2.5". Only place I have rock chips is the underneath part behind the front tire. Every truck I had got those even with factory wheels and tires. The chrome bars help block most of the rocks. When I roll through water or mud it does through it all on the side of my truck though. I guess if you don't mind spending the few extra dollars then it wouldn't hurt to get them.
Check out spike strider truck. He has the smooth style flares.
https://www.f150online.com/forums/me...e-strider.html
getting flares not only help with rocks and chips, it also keeps the truck cleaner. You don't get water and crap kicked up on the side of the truck.
Also, you may want to consider the legal requirements. I think that Minnesota only allows for 1" outside the fenders, then you have to have flares.
