03' Hub assembly require packing?
Update. Turns out the bearing can not be serviced. Straight forward replacement but I have an issue I'm looking for guidance with. Before the replacement there was an intermittent rub with each rotation of the wheel. May not have been a rub but sounded very similar. After replacing the hub there is a howl that increases intensity as the truck comes to a stop. Everything I've read about howling points to a bearing but this bearing is brand new. Is there something that I may have missed or done incorrectly that would cause this?
