Has been debated many times but still looking for real data...285/65/18 or 305/65/18?
I have searched and read a lot on hear about the tires I intend to put on my truck...BFG AT KO 285/65/18 or 305/65/18. I have a 2006 5.4L 4x4 Supercab with 3.55 LS gears and stock 32" tires (275/65/18).
I know that the 305's will look much better but I am worried about performance. With the 285's my effective gear ratio will drop to 3.48 and with the 305's my effective gear ratio will drop to 3.38. I do not have the cash to do a gear swap for the tires and most likely won't ever do one on this truck. I would love to but the cost is too much for me to justify.
I have seen many threads saying to go with the 305s, you will be fine. Well does anyone have actual data on these tires for performance loss? Has anyone been on a dyno before and after they had these tires? I am worried about my truck being sluggish when empty and even worse losing some of my pulling capacity. Basically I am looking for data so I can convince myself which way to go. If I had 3.73's I wouldn't be so hesitant but with the 3.55's I'm nervous. I would appreciate any more available info/data on a topic that I know has already been beat to death.
Thanks!
Thanks!
So I'm guessing no one has any real data on their performance losses with these larger tires but I did some more searching around and a little bit of math and found a few things. I read somewhere that you lose ~3.5% of your torque for every inch you increase your tire diameter. I did some quick calculations and confirmed that is a pretty close number...at least for the size tires I am working with. That ~3.5% loss seems to only take into account the larger diameter and not the extra resistance from the extra width.
So if my math is correct I don't see how someone who goes from 32" stock tires to a 34" (305/65/18) does not feel a significant performance loss? I read on here that there is some loss but that it is not very noticeable. Well if you increase 2 inches in diameter then that is ~7% loss of torque plus add the extra resistance from the wider tires and lift/leveling and you have lost ~10% of your original torque with stock tires. How can that great of a loss not feel significant? Am I off here with my figuring? If so I would appreciate it if someone would chime in. That is why I was looking for actual measured data.
Thanks again.
Thanks again.
Well just to throw my two cents in, just knowing about the couple trucks that I have put larger tires on in the past, your not gone to feel to much of a loss just on the average daily driving. Now if you are talking about pushing the towing limits of this truck then yea you are gone to feel it, and in that case I wouldn't do it. But I would say that most people that put the bigger tires on are not coming close to the towing capacity.
But ofcourse the rolling resistance will be greater and it will take a little more to get you up to speed which in return is seen in the city gas mileage. But being that I feel like these trucks feels like a dog most of the time, I would think about investing in a programmer...( it will correct the speedo change the shift point for the bigger tires, and give you back performance.) But if you had to think about it this much, and your not satisfied its a pretty exspensive mistake, like around 1300.
You're only going up an inch from the 285's to the 305's but you will lose some performance and a little less mpg's. The truck will definitly look better with the 305's. A programmer will surely help! Your truck will have to be leveled to run the 305's also, almost forgot that part!
Like I said I have an XCal3 programmer with custom tunes. I will be installing Bilsteins all the way around (2 inch lift setting on the fronts) and an add a leaf in the rear so fitting the 305's won't be an issue. You are correct that the 305's are only 1 inch bigger than the 285's but keep in mind my stockers on there now are 32's so the 305's will be 1.6 inches bigger than stock. The 285s will be .6 inches bigger than stock. I am estimating a 6-8% loss of torque/power with the 305s and a 2-3% loss with the 285s. I just need to understand if this loss is going to be bearable for everyday driving and towing. Also another thought coming to me now is...with the 3.55 gears and the 305s will my tranny wear out a lot faster from shifting more? As it is with the stockers it will shift out of OD on the express way when I get on the gas a little.
Hello everybody. I have a 2005 King Ranch 4x4 with stock 275/65r18. I need to replace my tires and I like the looks of the 305's. My question is what size leveling kit do I need and is it hard to install? My wife and kids use the truck also so I dont want to go WAY BIG on the lift. Thanks everyone. Lance
PawPaw, I see you have 34.4 inch tires. What gears are in your truck? I assume 3.73s? How does it feel around town and stuff and does it down shift a lot on the highway? Do you ever tow with them?
A 305x65x18 though is a little taller, close to 34 inches and that's where the problem is. Your 305x65x17's are right at 33 inches where a 305x70x17 is close to a 34 inch and probably would rub a little without cranking the T-bars a little on your 2000.
