Premature tire wear
Premature tire wear
Guys I spoke with a gentleman today that has an '04 with a lift and 35 ProComp Extreme AT's; he commented that these newer F-150 trucks really wear out the front tires prematurely do the the suspension. He says he goes through a new set of tires every 18 to 20K. He showed me what he was tlaking about, and you could actually see the cupping. He says that even rotating has not helped the issue as the cupping eventually gets so bad that the back tires feel like they bounce. He also said that he has tried several other brands of tires with the same results.
I am curious if anyone else out there is seeing the same issue?
Thanks for your time.
So I dunno.
