Wandell HELP
Wandell HELP
Tire shop just called and said they dont want to see my get Recoils because they are only going to be 8.5" wide. I want to run a 325/60R18 tire, which is 33x13R18 I believe.
They recommended the Helo HE791 with the following specs:
18x9 10 offset 5.39" bs 6x135
You think this will fit without rubbing on my truck?
I am not sure why they will not allow you to use an 8.5" wide wheel on the 33x13s, but they must be too narrow. All tires have a rim width specification that you can normally find on the company website.
I have an 18x9 wheel with 0 offset and 5" of BS with 33x12.5 Toyo MTs. I also have a 2" AS lift. My tires rub slightly on the drivers side lower valance when backing up. With a 1/2" wider tire and .39" more BS, yours will probably be about the same if the tire is an MT. An AT might just clear it due to a less aggressive tread pattern.
KR-Texas
KR-Texas
Toyos website does NOT recommend a 8.5" rim for use with the 325/60R18 so they were correct and no they were not trying to sell me on one rim over the other.
Anyway... I got 305/55R20 Toyo ATs on my stock wheels instead. They look sick and ride awesome, however I have very slight rubbing on the upper control arms at full lock. AHHHHH!!!
What can I do to correct this??? Is this tire just too big?
KR-Texas
KR-Texas
KR-Texas
KR-Texas
EDIT: This thread is from 4 months ago. Are you still having the problem?
KR-Texas
