18x7.5 OEM W/ 305/60/18
I agree with Wandell, a lot of member's are running the 305's on the stock wheels. 1/2" won't matter in the least. Those size tires on the stock wheels look great on a leveled 4x4. Check out some of the truck's on this site with that setup, they look great and have had no problem's.
When you squeeze a tire that wide that far inside of its rim range it stresses the shoulder area of the tire and crowns the treadcap. This overstress causes heat, which will be the demise of the tire. People do it, but just because you can does not mean you should.
