HELP!!! rim offset
HELP!!! rim offset
i am looking at these rims on ebay what offset do i need or would be good i have no idea about this stuff lol
http://cgi.ebay.ca/778-KMC-XD-MONSTE...ayphotohosting
If you want to run huge tires on just a leveling kit you want the 5.71" bs/+18mm offset. The +35mm will stick further in the fender and may cause tire rub on the upper control arm or rear shocks. The -12mm will make the tire stick way out and you could rub large tires on the fenders. It depends what look you are going for. If you have a 6" inch lift you want the -12mm. Hope that helps.
