What are you running suspension wise, just a 2.5"leveling kit and aal? Also what are the specs on your wheels?
I have the AS 2.5" kit on the front and the AS 3" block on the rear. works out perfect. the wheel is a 17x9, 6 on 135mm Bolt Pattern
Backspace = 4.75 in. Max Load = 2200lbs Finish = Flat Black Hub Centric = NoOffset = -6mm
