295/70R17 Nitto Terra Grappler
Yes, using the OEM wheels. They will be about 1/2 inch narrower than your current tires and about the same height (approximately 34 inches tall). Personally, I'd suggest installing a larger lift block or an add-a-leaf out back. It won't cost much more than removing the leveling kit (even if you do it yourself you will need a front end alignment) and it will be much easier.
