Question about new rims
Old 06-01-2009 | 09:34 PM
NawwMann772's Avatar
From: Raised In Hobe Sound, FL. Now Stationed In Kings Point, NY
im going to be getting 20 inch rims on my truck when i put my leveling kit with the add a leaf in the back. i was wonder about the offset of rims. i would like the tires to stick out about 2 to 3 inches. would there be any problems with that set up 20's on 35. and any recommendations on the tires i should get? a 285/65/20 bfg all terrane is pretty much a 35 right?
thanks
Old 06-01-2009 | 11:38 PM
wandell's Avatar
That's basically a 35x11.50 tire. To fit them you will have to use OEM wheels or one with identical specs (8.5 inches wide with 6.5 inches of bs). Since you want the tires to stick out, I'd suggest a 9 inch wide wheel with 5 inches of bs and some 305/55-20 (33x12.50) tires. These will stick out 2 inches farther than the OEM wheels.
Old 06-02-2009 | 07:54 PM
Thanks for the info. Do you know of any rims set up that would let me have that offset with the 35's on the leveling and add a leaf?
Old 06-02-2009 | 08:09 PM
aPINCHbetter90's Avatar
Im pretty sure this guys wheels stick about 2-1/4" farther out then stock and he has 35's with a leveling kit and three inch block
https://www.f150online.com/forums/wh...lots-pics.html
