New Wheels and Tires
Looks awesome, I just painted the inside of my headlights and if you just take your time they look great.Here is a link to help if you deciede to.
https://www.f150online.com/forums/ar...eadlights.html
Also I just did one coat of night shade on my tails and brake light cause I am always getting hasseled by local cops but you can still see the lights very well with only one coat and they still look good. I have pics in my gallery.
It is a 2wd. I had a AS 2.5 leveling kit on it but I found a killer deal on some camburg adjustable coilovers, so on they went. So the actual lift on the front is close to 3 inches. I know its not good for my upper ball joint but the camburg UCA is on its way.
The 315/70 BARELY fit. But after a little bit of trimming they are fine. They do still rub at about 3/4 lock in reverse. They will have to do until I can get my new tires on. I'm getting the 295/70/17 Nitto Terra Grap's or the Toyo AT's. Basically the same tire.
That one coat of nightshade really does look pretty good. And it's not TOO noticeable. Looks good!
