20x9 XD Monster with Toyo 33x12.5x20 MT (56K No)
Looks sweet!! The truck looks awesome but I think with a few changes it would be one of the best on this site for a leveled truck. IMO you should lose the chrome handles, mirror covers, and the bug shield. Aside from that I would change the FX4 decal out for one that is matte black to match the wheels. Those few things would really change the look of your truck. Like I said though..... it looks great now!
turck looks sick with the new wheels and tires man!!
sanding and painting running boards took about 60 minutes total...juse wet sanded with some 600 grit just enough to scuff them up, hosed them off then let them dry in the sun. Did 2 coats of Krylon black primer then 2 coats of Krylon satin black and let dry for about 3 hours before re-installing.
I also had a hard time choosing between the Monsters and the Rockstars. I had the same dilemma with the 18x9 Rockstars and how you could put your hand in to touch the lugs, but I found a very nice solution. Another member showed how he cut the four plastic mounts on the stars and the long allen bolts 1 1/8" to bring them in closer to the wheel. It looks very good on an 18" wheel and will look even better on a 20".
Here is what mine look like after the modification. Problem solved!!
![rocker](https://www.f150online.com/forums/images/smilies/rocker.gif)
![](https://www.f150online.com/forums/members/kr-texas-albums-wheels-badges-running-boards-inlays-overlays-picture29533-star-top.jpg)
![](https://www.f150online.com/forums/members/kr-texas-albums-wheels-badges-running-boards-inlays-overlays-picture29534-star-front.jpg)
KR-Texas
I'm going to order the same wheels/size but got confused on the bolt pattern! I'm not pro into wheels/tyres so please help. ![Confused](https://www.f150online.com/forums/images/smilies/confused.gif)
which one?
20x9, 5 on150 Bolt Pattern
20x9, 5 on5.5 And 5 on150 Bolt Pattern
20x9, 6 on135 And 6 on5.5 Bolt Pattern
20x9, 8 on170 Bolt Pattern
20x9, 8 on6.5 Bolt Pattern
Thank you :o
which one?
Thank you :o
