wheels with lift help!!
So I have the 6" rough counrty lift. My truck is an 04 f150(new body style) and I have the rockstar wheels in 20x8.5 and toyo mt 35x1250x20 tires. I thought I ordered the 20x10 wheels but something happened along the way and these are the wheels I got. I called the 4 wheel drive shop that is suppose to put my lift on this thursday and he said that it should work out fine. I have read around the web and I have read that it will and wont work. So Im nervous for thursday to roll around. Any advice on this topic? The wheels are 20x8.5 with a 35mm offset and 6x135mm not sure what that part is. But anyways please help me out because I really want this to work!!!
The offset is what may cause issues. A +35mm offset is pretty much a factory offset. With a 12.5" wide tire the tire will probably rub on the knuckle or on your chassis when you're at full turn. Also the wheel will stick in the fender like a factory wheel. It's not the look I like when lifting a truck, but everyone likes different things. IMO on a lifted truck a - offset wheel looks much better.
if you are stuck with the wheels then you could always use spacers to make them fit but they are not recommended
