Will these fit?
Old 06-22-2009 | 08:45 PM
resante's Avatar
Will these fit?
I'm getting ready to purchase some wheels & tires but not sure if they will fit/rub. I have a 06 4x4 with 2" AS & I'm looking at XD Diesel size: 20x10 Bolt Circle 6x135 Offset -24 Backside Setting 4.56 wrapped in Toyo MT 33X12.50R20.
Also if anyone has or knows anyone with this setup I'm curious how they'll look & how far they will stick out. thanks
Old 06-22-2009 | 09:04 PM
Big_Smokey's Avatar
I have -12 offset...20x9's You can check my gallery pics of them to see how far they stick out and add an inch. You are going to rub pretty badly with that wide of wheel with that backspacing... I rub and im running 305/55/20 TG's. Theres a start for ya! You might read through this post. This guy has a 2" AS and 33's
https://www.f150online.com/forums/wh...mt-56k-no.html
Old 06-22-2009 | 09:15 PM
shawnp's Avatar
Look for a wheel with a positive offset. Are you looking at the dually wheels?
Old 06-22-2009 | 09:18 PM
resante's Avatar
Ahh yeah it was the only available size in that wheel for 20". You wouldn't by chance know the max width I could go without rubbing, do you? I was also looking at another set with +18 Offset and 4.79 BS
Old 06-22-2009 | 09:22 PM
resante's Avatar
No it's a 4x4 xlt. I dont want them sticking out 1+ inches but at the same time I dont want them hidden in the wheel well when looking from the rear.
Old 06-22-2009 | 09:33 PM
shawnp's Avatar
I would find something with a plus 18 offset and go with a 9 or 10 wide wheel. Call rimzone or 4wheelparts and they should be able to tell you exactly what you need.
Old 06-22-2009 | 09:38 PM
resante's Avatar
Ok thanks shawn, I'm looking on rimzone as we speak. I'm definatly going to be purchasing from them. Great prices!
Old 06-22-2009 | 10:24 PM
Big_Smokey's Avatar
Thats where I just got mine from... I had good luck with them. Good prices and about 3 or 4 days later i had them here in MO
Old 06-22-2009 | 10:29 PM
HighOn22's's Avatar
I'm running the 22x11 Diesels with -25 offset with 37's. They do stick out some, but I prefer the way it looks compared to a + offset. When I was running 35's with a 6" lift they rubbed on the back of my front fender so I had to trim the fender flare.
Old 06-23-2009 | 12:18 AM
wandell's Avatar
Those wheels will stick out 3.5 inches farther than your OEM wheels. They will fit with 33's but you will have to do some trimming.
Old 06-23-2009 | 07:58 PM
resante's Avatar
Hey HighOn22 I saw your truck & instantly I wanted those rims. Awesome ride man. Only if they made them in 20x9. I really don't feel comfortable trimming around the wheel well. Thanks wandell, that's sticking out way 2 far for my liking. How about 20x9 +30mm offset & 6.18 BS on 285/65R20? Sorry for all the questions, I have about 2 more pay checks before I can actually buy them so I'm trying to do my research.
Old 06-24-2009 | 12:19 AM
wandell's Avatar
A 9 inch wheel with 6.1 inches of BS is gonna stick out about an inch farther than the OEM wheels.
Old 06-24-2009 | 06:09 PM
HighOn22's's Avatar
The -25 I find looks good on a lifted truck. It gives that wide, aggressive stance. Some don't care for it b/c it throws objects on the side of ur truck if you offroad often. If you don't want that low of an offset there are several 20x10 and 20x9 wheels with around a -12 or -18 offset that would look good. IMO I wouldn't do something as high as a +30 offset. Thats to far in and will likly rub on ur control arm when at full turn due to the tire width. I would stay in the range of +18 to -18 offset. The - will also give you a larger lip on the rim.
Old 06-24-2009 | 07:31 PM
resante's Avatar
Damn are you serious.. Found another truck with that rim & tire size that looked sweet. So basically I want to stay under +18 offset so I don't damage my control arm? Thanks 4 the help fellas
Old 06-24-2009 | 07:56 PM
aPINCHbetter90's Avatar
I would consider looking at the 18x9's there 5" of BS and 0 offset more around what your looking for I have a 17x8 wheel with +18 offset and 5.2" of BS and stick out 1.25" farther than stock.
