HD 22's on a 2006 SCrew 4x4
The TPMS is the only thing that complicates the installation. If the sensors are included you should be able to bolt them on and have them recalibrated for your truck. If the sensors are not included you have a couple of options. Personally, I'd install them without the sensors and put up with the warning light. You could also remove the sensors from your OEM wheels and have them installed on your wheels. You will have to buy new mounting bands to do this. The other option is to buy new sensors and bands to install on the 22's.
Also, the OEM 22 inch tires are gonna look really small on your 4x4 if you don't lower it. Or, you could install larger tires.
