ABS Problems on 2003 F150
The ABS light came on. Found 50A (Fuse 102) was blown.
I replaced it and the ABS pump ran for 15 to 20 seconds than it stopped. The ABS light went out and worked for two short trips and the fuse blew again.
I went to the local Pep Boys and they read the codes for me as my regular OBD scanner would pick up the ABS codes.
They readback codes B1676 -Battery Voltage Out of Range, C1185 -ABS Power Relay Output Circuit Fault and C1096 Hydraulic Pump Motor Circuit Open.
I checked the wiring and didn't see any obvious shorts.
Any suggestions would be greatly apreciated
Thanks!!!!
Thanks!!!!
