? for wandell or anyone willing to answer
I ordered the rockstars in a 20x8.5- +10mm and +35mm offset, just making sure this will be a safe fit for a set of 35/12.5/20 toyo mts?
i believe i will be ok, but just wanted to make sure before i ordered the tires, i didnt want the 20x10,
oh yeah, ive got an 07 4x4, and ive got a ranchhand front bumper, so ive got more clearance if that helps
Yep, we need to know this before anyone can help ya. The wheel you are looking at has 6.1" backspace. If you only have a level kit it will probably rub the A arms because of the large side lugs of a mud tire. Someone that has that tire size might chime in. If you have a 6" suspension lift, you will have to check with the manufacturer to see what backspace is compatable with their lift. If you have no lift or level kit ......... keep dreaming.
