Will these rims fit?.........
Thanks for your patience Wandell........
but this backspacing stuff is close to rocket science.... for me at least!
The tire size I'm running is 305/55/20 (Nitto TG's) currently on OEM wheels. No rubbing issues although there is not a lot of room to spare between the tire and the upper control arm.
My feeble mind says that if the wheel is 1/2 inch wider but it sticks out an 1&1/4 inches farther that the diff is a wash (with respect to the control arm) and there should be no problems. But something also tells me that the fact that they stick out farther really means nothing, it's the difference in the backspacing that's the critical factor. I'm probably all wet here, please clarify if you can. I don't want to purchase these wheels and find out I'm they won't work. Thanks again
Appreciate your assistance Wandell.......
![banana](https://www.f150online.com/forums/images/smilies/banana.gif)
