Rear Brake Rotor Change
I tried searching and found a few threads on the front pads and rotors, but I need to change out my drivers side rear rotor. I had metal to metal from the old pads and the rotor is all sorts of messed up. If anyone could give a little right up on this that would be awesome. Right now im running brand new pads on the crap rotor and i know thats not good. Thanks for anything
never owned a vehicle without the factory service manual. it's worth its weight in gold, although admittedly the price of admission is getting seriously out of hand lately.
Most of the times it's a couple of caliper bolts and if you have to, back off the parking brake drum shoes. If it's only one side you should seriously look at replacing/rebuilding that caliper too.
not sure this really helps you but im looking into the APracing products from stillen. they have rear replacement rotors that are drilled and slotted.
http://www.stillen.com/browse.asp?c=...D&model=PICKUP
good luck.
good luck.
Well thanks for the replies. I finally went and bought the Haynes Manual. Just a small $25 . It definitly seems to be worth it. I found out how to remove the rotor, and it seems like its gonna only be a few bolts so we shall see what happens. Thanks for the link WhiteRoush3 but i think im gonna just go with some from Advance Auto, it'll be alittle cheaper. Thanks again everybody. I'll let yall know when i get it done. Just gotta go get a rotor.
good choice not getting the drilled and slotted.... nothing against those that opt for it.. but drilled rotors are prone to cracking, and slotted rotors are overkill in 99% of daily driving applications. all it does it lighten your wallet a little more.
as far as your rotor swap, i take it the caliper on that wheel has been off recently if your running new pads on a crap rotor...
so the caliper should come off easy.
in my experience the rear rotors dont come off as easy as the fronts... dont know why lol.
but a pry bar placed in some well planned places (dont bend anything you dont have too... dust shield doesnt matter, it can be bent back easily, but dont bend something thats gonna break.... and maybe a hammer to hammer the old one off......
if you have a caliper piston compression tool by any chance, you can wedge it between the rotor and the caliper mount and use that to pry the rotor off...
but your trucks pretty new so you might not have any problems at all.
good luck.
good luck.
For future reference, the rotor is not stuck on the lugs. It's stuck on the axle hub. Take the caliper off, then drive the rotor off using to bolts and 4 nuts. There are videos on it.
