Tire question.......
Yup... its cuz of the fact that your pushing more rubber around and heavier so it takes more to do the same you did with stock tires.
i got about 16.5 MPG on the first tank after doing the "Gotts" and K&N drop in then i got the 33"s and went to 14 for the trip to college station (cuz i average 85) and then back to 15 on last tank.
Like others have said, and from my extensive research on this subject, I'd say you'd lose .5-1mpg if your driving habits don't change.
The CAI on the 3v 5.4's need a tuner to make the motor run right. They lean out with just a CAI and can cause catastropic failures. I wouldn't suggest it unless you have a tuner/get a tuner with it.
I put a K&N drop in, in my truck. Soley because I got a huge discount and its reusable. It did 'feel' like there was a bit more throttle response, but MPG didn't change til I did the exhaust, then it went up a solid 1.5mpg. This is over about 5000 miles of driving since then.
Its a truck, MPG is always going to be low/suck! HAHAHA
