Rancho Quick lift done, what tire size to run?
Old 08-21-2009, 10:19 PM
Taxman09's Avatar
Installed the Rancho Quick lift on my truck yesterday, 2004 FX-4, now I'm wondering what size tires I can fit with no problems using my stock 18" rims ? Would a 35 12.50-18 fit with no issues ?
Old 08-21-2009, 11:42 PM
BLUEBEAST06FX4's Avatar
Yes sir it definently should because isn't the Rancho Quick Lift just like a 2.5" leveling kit?
Old 08-21-2009, 11:46 PM
Taxman09's Avatar
I think Rancho claims 2" Would I be better off going to a 35 12.50 17 and after market wheels ?
Old 08-22-2009, 12:17 AM
Wheel size isnt really gonna affect anything it all depends on the offset and backspacing. It's all personal preference on if you want to keep your stockers or go with some aftermarket 17's. Got any pics of the truck?
Old 08-22-2009, 12:21 AM
Taxman09's Avatar
No pics, sorry, I found a set of used 35 12.50 18's and a set of the same in 17" just wanted to know which will fit best without rubbing or having to cut and grind ?
Old 08-22-2009, 12:29 AM
I say to go ahead and save yourself some money and just the used 35x12.50x18's that way you don't have to buy new rims. You may have to do minor trimming but nothing noticable....
https://www.f150online.com/forums/20...installed.html
This should be the answer to your question
Old 08-22-2009, 10:43 AM
wandell's Avatar
You can fit a 35x12.50 using the OEM wheels or an aftermarket 8 inch wide wheel with 5.5 inches of backspacing, but they will rub the control arms slightly at full steering lock.
Old 08-22-2009, 11:06 AM
Taxman09's Avatar
So they will rub regardless, next question, any idea how much milage I'd lose by running the 35's ?
Old 08-22-2009, 11:15 AM
Im seeing about 10-11 MPG's with city and a tad bit of highway every tank. If cruising at 60 I can see as high as 16
Old 08-22-2009, 11:32 AM
Taxman09's Avatar
I have 275 65 18's right now, I have been averaging a little over 15 MPG, if I do alot of freeway it goes up a little but not much. The 35 12.50-18's I can get are Toyo MT's by the way, should I pass and go with a better fitting 33" tire instead ?
Old 08-22-2009, 04:42 PM
jlgil73's Avatar
I get 13-14 mpgs on an average tank. Gas is like beer, when I need it I buy it.
Old 08-22-2009, 06:03 PM
Taxman09's Avatar
I have a mortgage and a family with associated bills, I can't afford that kind of attitude about it, sorry!
Old 08-22-2009, 09:44 PM
mishka's Avatar
I had 33x12.5 on 18 on my '06 and didn't find them too small at all. Personal preference i guess but 35's look too big with only a leveling kit imo. Also with the 33's you can go for a little less offset so they stick out a bit more than stock and not worry about rubbing.
Old 08-22-2009, 11:17 PM
Taxman09's Avatar
SO what width and offset /backspacing should I be looking for in an aftermarket wheel ?
Old 08-23-2009, 12:14 AM
A 305x65x18 BFG AT which is close to 34 inches tall will fit and look great. Kind of split's the difference!
Quick Reply: Rancho Quick lift done, what tire size to run?
