cant make up my mind on rims
i just got a 09 screw xlt i dont know what i want to do on rim size im going with the street scene i been thinkin about doing a 2inch level lift on the front and fitting 28 inch rims or doing the 2 inch drop on the back with 24 inch rims this is gonna be a sho truck when im done what yal think
Never, never, ever lift a truck to fit a street tire/wheel package. You don't want to wind up with a F-150 donk. A very small number of people like that look but the majority of the world laughs at it. I'd suggest lowering the rear with lowering shackles and go with a set of 24's or 26's. I'm not sure if you can fit 28's, but you probably can. Just be sure the size you pick looks preportion to your truck. Since you have a Screw, 26's will look fine. Most of the wheel manufacturers these days do a great job with the width and backspacing larger wheels. Just be leary of any wheel with a dual bolt pattern as that is usually a sign that the width/backspacing has been compromised to make it "kinda fit" a couple different vehicle. I have a friend that easily fit 24's on his stock Escalade and recently moved up to 26's, all at stock height. They look great and don't rub or hang outside the wheelwells.
